Im running valveoline 5w30 right now. Im doing a oil change in a few weeks, would anyone sugguest synthetic or half n half?
Pretty much the same thing i was saying Thanks for clairifying it a little more in depth than i can tho.How synthetics are made.
Some synthetic fluids are produced through a synthesis process that takes very small molecules and assemble them into larger designer molecules with premium lubricating properties. Others may be produced through a synthesis process that takes very large molecules, breaks them apart and re-arranges them to produce designer molecules with premium lubricating properties. In either case the end products are base fluids with extremely good lubricating properties. However, all of them also carry with them certain inherent disadvantages.
Synthetic Motor Oil Advantages
• Breakdown Resistance: Increased thermal and oxidation stability.
• Deposit Control: Reduces formation of sludge and varnish deposits.
• Wear Protection: Improves oil film strength and breakdown resistance.
• Volatility: Lowers oil vaporization and consumption at extreme conditions.
• Cold Start Properties: Flows easily at low temperature.
Philip Medlock Valvoline Technical Specialist.
VISIT WWW.BOBISTHEOILGUY.COM THEY DO USED OIL ANALYSIS ALL THE TIME PENNZOIL PLATINUM SHOWS THE BEST NUMBERS WITH 5W30 EVEN AFTER 12000 MILESi run castrol syntech blend in my truck, since i change the oil at 3k miles.
i've ran full synth before and it looks brand new when you drain it at 3k. so i decided to get the best of both worlds and save a little $.
synth oil is better on paper, but i've seen motors on dyno oil last just as long as synth oil. it all depends on how well the motor is taken care off and how it is driven.
i also use either a Wix or a AC Delco filter when i change my oil.
