A/C Leak at Low Service Port
1 reading
7.1K views 9 replies 5 participants last post by  beandip
Last summer my A/C wasn't as cold as it used to be, so I had the system evacuated and recharged with "Red Tek" kit from the local parts store. As I was finishing up the job I noticed that I could hear a leak from the low service port when I removed the hose. I put the black plastic cap back on good and tight and the leaking sounds went away so I left it alone.
A/C worked great all last summer, but as I suspected over the winter the coolant leaked out and now the compressor doesn't want to engage. I figure that leak I noticed at the low service port is the problem so I'd like to fix it before recharging.
I've never done this before so:
*Can I just use some of the "A/C stop leak" stuff the auto parts stores sell??....probably not right?
*How would I go about fixing the low service port? I imagine there must be an o-ring or something inside the service port that has sprung a leak??
#2 ·
The plastic cap needs to be on to stop that small leak when you take the charge hose off, AFAIK that's normal. I think you need to find out where the refrigerant went the 1st time you re-charged it, because that's probably where it leaked this time. Also you need to monitor the hi & lo pressures when you're charging.
#3 ·
if it were me I would not use a stop leak because it is a temp fix (if at all) - overall I think if you fix something do it right and do it once (and take your time)
so...i've fixed my high side port before and used the PAG oil to lube the oring - other guys like to use stuff called nylog (thread/gasket sealant)
the low side will be either a schrader valve or port fitting (i'm pretty sure it will be a port fitting) - they are commonly available at autoparts stores
ck out pics of both below - good luck
ps. if you haven't done a leak check on your system - i would check either monitor vacuum or pressure test. if you skip this then at least use UV additive in refrigerant so you can trace the prob. (or perhaps if you still have charge add UV now and leak check)
#7 ·
When I completely changed out my ac (done quite a few trucks as well) I found that valve to be a tad sticky.
Get some needle nose pliers and gently pull on the pin on the valve. Should help close it as that is what I have to do.
Every time I service an a/c system I always leak test those ports with soapy water then dry them off.
That rubbery ball valve is on the high side.
#9 ·
For anyone who my by reading this. I recharged my system and I followed Bean's advice and pulled on the pin a little bit with some needle nose, and the leak stopped! I double checked it with soapy water and it's holding tight.
#10 ·
Glad to hear that worked :)
its stupid i know, but sometimes you gotta manipulate the valve, then check for leaks. high test port especially.
