Alright, well if you read my other threads you will know that i bought a truck with front airbags that were done quite right and need replacing. Well now when i turn i hear a "ticking" noise coming from the front suspension. So i guess its the ball joints. The rubber things on the ball joints that holds the greese are all leaking. I put greese in them but it didnt do any good. So now here are the questions I have..
1. Why do you think they went out.. the truck has 55kmiles on it. Probably because he never greesed them up? (pretty sure he never did)
2. I was reading my Haynes manual and seeing how to do this. Should i be able to do the work myself? I read i will have to get a shop to press in a new ball joint in the lower control arm.. so what i just have to take them off and bring it down there? How much should that cost?
3. When i get my bags fixed... if i set the truck at my normal riding hight and get the front end aligned then should my ball joints have problems in the future? Basically what i am asking is this.. because i have bags will my ball joints keep going out on me?
let me know what you guys think.. thanks
- Mike
- Mike
